Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14076 Registered: Oct-05 | for people that wants to install their component speakers in the kick panel, q-logic makes some nice ones. they have one more most cars. go to this site and select your car. http://www.crutchfield.com/S-XKgAP3GbcSc/cgi-bin/ProdGroup.asp?search=qlogic+kick+panel&skipvs=T&g=182850 this is the one i'll be getting. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3464 Registered: Jul-06 | Those look pretty sweet,post pics of before and after they're installed. |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 950 Registered: Nov-05 | screw holes fit into existing stock screw holes? or drilling required? and i just looked they dont make one for my vehicle. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14077 Registered: Oct-05 | will do. it matches the interior of my car pretty well. at least from looking at the picture it seems like it. also i will be going with a mmats 3 way component speakers. i got to hear a demo in a honda accord and it sounded awesome. very nice response to all frequencies. |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1840 Registered: Jul-05 | build your own chad. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14078 Registered: Oct-05 | btw the i can get the mmats 3 way for only 400 bux. jk the screw holes go in to the existing hole. i saw one in person and it is simple to install. i just take the existing kick panel out and replace it with this one. on the driver side it looks a little different. it has the hole for my hood realese. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14079 Registered: Oct-05 | jake too much work. lol. besides i found one on ebay that is for my car. 2 days left and the price right now is 20 bux. shhhhhhh don't tell no one. |
Gold Member Username: JohnfiacA-ToWn, 9515 thumpin... What u bumpin? Post Number: 3314 Registered: Mar-06 | none that fit my car either :\ |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 4789 Registered: Jan-06 | sorry chad, but iv looked into those kicks and found out they are basically crap. from what i hear they are made from cheap plastic and they dont really seal the speaker off at all. just build your own. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14080 Registered: Oct-05 | here is what it would look like in my car. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14081 Registered: Oct-05 | mat i know they are cheap. once i get them i have to do some work to it to make it just right. important thing is it has the shape already made. |
Gold Member Username: Adam_sPost Number: 1581 Registered: Aug-04 | Ok This is kind of a newb question, is it really better to have kick panels verses just putting them in the stock location? And what makes it better if it is. |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1818 Registered: Aug-06 | one thing that makes them better is imaging. the sound really hits you more than when it is all just blasting the side of your leg. also, the addition makes it just THAT much louder so if your trying to keep up with alot of bass it comes in very handy as well. those ones really are kinda crappy but if you arent a total idiot or already have SOME kind of fiberglassing skills you can make them work ALOT better than just throwing them in there. its almost as bad as just throwing a component set in an '88 cutlass... install seriously is everything, all the way down to those tweeters. ive heard some terrible setups with what were supposed to be nice top of the line component sets... |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1819 Registered: Aug-06 | *in the doors of an '88 cutlass... |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3466 Registered: Jul-06 | Before you do any custom work Chad just listen to how they sound first.You may be pleased with the way they sound from the factory. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14082 Registered: Oct-05 | ok i have heard them in those enclusers and they sound very nice. here is how it is going to be installed. tweets......enclosure isn't important but the location is. that kick panel will provide a good location. mids.......it does requier a nice enlosed space for it to sound good. most likely i will make a ring out of thin mdf to put the speaker so it don't resonate. woofer.....will go in my door panel on the stock location. "those ones really are kinda crappy but if you arent a total idiot or already have SOME kind of fiberglassing skills you can make them work ALOT better than just throwing them in there. its almost as bad as just throwing a component set in an '88 cutlass... " call me an idiot but i don't think i can make one that will fit perfectly in that location. also if the fiberglassing is important, then i can just coat it with resin. its as simple as that. it seems like everyone on this forum is a pro at making kick pods but i have not seen a single person that did it. |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1820 Registered: Aug-06 | "call me an idiot but i don't think i can make one that will fit perfectly in that location." i actually meant if you couldnt think of ANYTHING, as little as sealing it off with your car, dynamatting the inside, or... coat it with resin... and read it again, i didnt "make them" i said "make them work ALOT better" as in custom customizing them... |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 4794 Registered: Jan-06 | i have fiberglassing skills, i do repair work on boats and have done a few custom pieces as well.. i just have no space to put kick pannels in my little car. its stick and because of the clutch petal i have no extra room on the drivers side for them. but as long as you do some work to those it should make them alot better. also you might want to consider useing them to get measurements from to make your own and if they dont turn out use those. but with a few mods they should turn out good. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3469 Registered: Jul-06 | "it seems like everyone on this forum is a pro at making kick pods but i have not seen a single person that did it." Lol.Snappin on people Chad!Whooo whooo!The only thing I would do is exactly what you said about the resin,I was going to mention that but I figured you'd think the same a little silicone sealant around the edges would help in case of leaks.Just make sure to use clear tape around those edge first if you have any so you don't mess up the carpet at all. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14083 Registered: Oct-05 | oops tremor. i mis read your post. lol. sorry? ") |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1821 Registered: Aug-06 | yeah dude its cool... all im saying is when you buy them, they are a bent up piece of plastic. ive heard several of the q logic's, i even owned a pair in my 96 neon which i did nothing to other than took them out of the box and installed them in the car. they sounded good but a real set of handmade sealed kick pods is where its at. but whatever, who are you competing with? } |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1822 Registered: Aug-06 | haha, yeah you misread that bad... is it my texan accent? |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1824 Registered: Aug-06 | https://www.ecoustics.com/electronics/forum/car-audio/368278.html |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14085 Registered: Oct-05 | lol funny stuff there. |
Gold Member Username: BernymacBME, BernyMac Edi... Post Number: 3058 Registered: Sep-04 | Great choice in the mmats components chad, I heard them in an accord a couple of years back that they sounded amazing. The whole vehicle was sq, it was the best sq car I have ever heard so far. I'm sure you'll be happy with those mmats components. |
Silver Member Username: BasssquaredKansas Post Number: 924 Registered: Nov-06 | read this review Chad oh and by the way did you send it yet? I've always looked forward to installing a set of components in the kick panels, and I was lucky enough (or so I thought) that Q-Logic made them for my 97 GTi. To sum it up quickly: The finish is noticeably different than OEM (even for black), I had to trim a huge amount of material just to squeeze the passenger panel in to clear the heater box, and it still didn't fit right; the driver's side kick panel, no matter where it's mounted, required huge cutting to clear the hood release, and it's still difficult to open the hood; both sides absolutely do not fit right, even after 5 hours of trimming, removing, refitting, etc. They were not worth losing the dead pedal, even taking in to consideration the improvement in sound. Save your money, put the 150 towards a nicer set of components or 2 ways. Sorry folks! |
Gold Member Username: JohnfiacA-ToWn, 9515 thumpin... What u bumpin? Post Number: 3323 Registered: Mar-06 | from the pictures chad posted i would think the person had the wrong set of panels shipped to him, or didnt know what he was doing like removing the old panels before putting new ones in place lol, the pic looks fine. |
Platinum Member Username: BestmankindSQ = SoundSplinter RL-s Post Number: 14090 Registered: Oct-05 | yeah i mailed out the stickers on friday raymond. i did read the review. i ain't paying 120bux for that either. i am bidding on one on ebay. |
Silver Member Username: MesodummTri-City, Az Usa Post Number: 149 Registered: Apr-07 | I do mostly custom boxes and kick panels I am working on some for 2006 Monte Carlo right now. mine do cost a little more but for getting fiberglass compared to cheap plastic its worth it. You can see some on my site in pic's at www.myspace.com/uroc_97_tj I use PayPal so you don't have to worry about getting them or your money back. I do list my kick pods on Ebay also. Jeep has always been my main market because because nobody really makes quality stuff for them! The Mod Pods are the only other speaker pods made for them and it is right in the way so you drag dirt, mud, and water in right on top of it. Also they are plastic so if you have ever heard the difference you will understand why fiberglass is the only way to go!!! |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3494 Registered: Jul-06 | Would you like to attemp to make something for a 1993 GMC Safari? |
Silver Member Username: MesodummTri-City, Az Usa Post Number: 150 Registered: Apr-07 | I will have to locate one here local, and make a template for it, I will give anything a try! Let me run auto trader and I'll get back with you okay? Thanks |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3497 Registered: Jul-06 | Alright,let me know what's up but I already know it's a project but just keep me posted |
Gold Member Username: BernymacBME, BernyMac Edi... Post Number: 3064 Registered: Sep-04 | I just finished putting a layer of resin onto my doors Chad. Then later I'm going to mount the speaker ring to the door, wrap it, resin, and then lets see what happens from there. Now I have to go to sleep. Anyways, hit me up when you plan to go to Chad Gearys place. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3504 Registered: Jul-06 | Nice Berny but where are the pics?! |
Gold Member Username: BernymacBME, BernyMac Edi... Post Number: 3067 Registered: Sep-04 | Its ugly right now, I will take pics after I wrap it lol. |
Silver Member Username: Mike11202Sewell, NJ US Post Number: 777 Registered: Nov-06 | mesodumm what about an 06-07 honda civic coupe? |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3509 Registered: Jul-06 | "mesodumm what about an 06-07 honda civic coupe?" You go away and you go away now!Me first! |
Silver Member Username: MesodummTri-City, Az Usa Post Number: 151 Registered: Apr-07 | no problem! I've done quite a few honda's, my computer crashed 2 weeks ago so I have to go through the back up disc's to find all my photo's |
Silver Member Username: Mike11202Sewell, NJ US Post Number: 779 Registered: Nov-06 | |
Silver Member Username: Mike11202Sewell, NJ US Post Number: 780 Registered: Nov-06 | so u can do the kickpanels for my civic? |
