Help asap!!!
Username: Aaronjp1990
Lerwick, Shetland Uk
Post Number: 120
got my sound system in today everything works but when i use the ipod (alpine 9855 with ipod interface thing) i get no sound it is connected and i can select music of the ipod but there is no sound?
Username: Oglejust
Post Number: 2195
do u have remote antenna on ur car?
SQ = SoundSplinter RL-s
Post Number: 14057
where do you have the cable that goes to the hu connected? i had the similiar problem with mine. i have the pioneer ipod interface.
i connected mine to the input of the interface when it should of been in the output. when i connected to the input i was able to choose songs and stuff but no sound was coming out. after i changed it to the output part, i was getting sound.
Post Number: 121
remote antenna an aerial? then yes. its connected into the only one it can fit into. could they maby be a setting somewehere that needs changing?
Post Number: 14058
oh.
also try turning the eq function off on your ipod.
Post Number: 122
ok ill try that in a minit to failing that i will phone alpine on monday
