Looking into an upgrade
Username: Orange93
BF , Idaho
Post Number: 42
I'm looking at buying an Adire Brahma mk1 from a guy. I was wondering if I would be happy with this sub if I were to put 1000 watts rms to it and a 1.6 cu. ft. box. Also do you have any reccomendations on an amp that would be good to use with it?
Username: Adddisorder
West palm, Florida
Post Number: 4206
depends how much are you paying for it
Username: Orange93
BF , Idaho
Post Number: 43
Idk it's on ebay and it looks to be in good shape.
It says its 10/10 functionality and 9/10 cosmetically too.
Username: Southernrebel
Post Number: 4908
what size brahma?
Username: Orange93
BF , Idaho
Post Number: 44
12"
Post Number: 4909
If you are going sealed w/ 1 brahma 12", try 1cuft net. You will get a QTC of ~0.66
Username: Orange93
BF , Idaho
Post Number: 45
The box dimensions are The dimensions for the 12" box are
14" in height,
16" in width and
the inner ring is 11 1/4 "
the outer ring diameter is 13 1/8"
It's kinda a cylindrical fiberglass box. I'm not completely sure about the cu. footage. Here's what the box looks like.
Username: Orange93
BF , Idaho
Post Number: 48
You guys think a Orion 1200d would be good to power the sub?
