2 kicker CVR's or 1 L7?
Username: Chriscf817
TX
Post Number: 11
i have a u.s. amps 1600.2 amp that gives out 1100 rms at 4 ohms. and right now i have 2 cvr 12's that are 4 ohm dvc and are wired in series. but they guy at the store said that maybe if i go with just one 12''L7 in a ported box that it would sound louder.
i was going to buy a ported box for the cvr's but before i do that i found out that i could trade them with the sealed box for a L7.
so which would sound louder? the 2 cvr's or 1 L7. should i go head and get the ported box for the cvr's or trade for the L7?
Username: Ctmike
Ct.
Post Number: 4211
2 ported cvr's. but why kicker?
Username: Waterboy2289
Georgia, DiRtY SoUtH ... 2 18 SX w/ ...
Post Number: 337
The two 12" CVRs will be louder than one 12" L7. KEEP the CVRs!
Is the guy at the store going to make the ported box or has it already been made? How much are they going to charge for it?
TX
Post Number: 12
because i got them real cheap. what do u suggest?
Post Number: 338
Since you already have them, keep them.
How much did you pay per sub?
TX
Post Number: 13
its already made. its the box they give you when you buy the L7
TX
Post Number: 14
130 for both brand new
Post Number: 340
That was a good price!
You don't want to buy a pre-made box like the guy is trying to sell you at the store. You won't get anywhere near the maximum performance from your subs! READ BELOW.
Can you build your own box? If not, contact somebody like Mark Potts, Logan, or Pete from TTB and get your enclosure done right! It is the most important part of your system.
TX
Post Number: 15
how much would it be for a ported enslosure that'll fit a 99 mustang?
Post Number: 341
You would have to ask one of the guys listed above. The best option for you would probably be Logan since he is on this forum and should be able to build it at a decent price.
