I was wondering what your opinion would be for the best choice for SQ and i will go with the option that would allow me to keep my stock alternator, I do not think I want to deal with putting a HO alternator right now, the car is new.
At this moment I will not upgrade the factory satellite speakers, neither the factory head unit.(but I will upgrade them later on)
Jl 500/1 and single brahma 10" (maybe 12") or
Jl 250/1 and single shiva 12" or
Jl 500/1 and single shiva 12""or
jl 250/1 and single brahma 10" ( maybe 12")
I would only like to run the amps at 4 omh.
Thank you very much
Robert J
well i don't know that much about shiva but i own a brahma 12", and i only put 340rms to it. you really don't need more than that. A guy from adire also owns a brahma and he uses the the same amp that you listed above(JL 250/1) and that would be at 4ohms. The thing with the brahma you need to have a very good box. i had a Q-logic sealed box and had kicker compvrs in it and they sounded good, then i put the brahma in there and i could hear every air leak there was, sounded really bad. then i just made a custom one for it and sealled really well, sounds amazing. you won't be disapointed with a brahma.
But wait for more posts to see what people say about shiva and how they compare.
