Username: Doexinggts Post Number: 7 Registered: Apr-04
Monday, May 10, 2004 - 21:15 GMT will the jbl bp600.1 push the 15" brahma ? or will the kicker be a better solution ? thx
Username: Glasswolf NorthWest,
Michigan
Post Number: 2829 Registered: Dec-03
Monday, May 10, 2004 - 21:38 GMT if the Brahme presents a 2 ohm load, yes the bp600.1 would drive it. Maybe not to it's maximum output but it will drive hard.
Username: Doexinggts Post Number: 8 Registered: Apr-04
Monday, May 10, 2004 - 22:02 GMT kicker 600.1 i meant, another question is 2 12" shiva good with those amp ? or is it too less power ? thx glass
Michigan
Post Number: 2857 Registered: Dec-03
Tuesday, May 11, 2004 - 18:48 GMT eh with two shivas you'd be better giving each one about 600 watts.. not 300 wach
Username: Newb Post Number: 135 Registered: Dec-03
Tuesday, May 11, 2004 - 20:38 GMT when is the mechanical xmax reached for a shiva? prolly around 450w?
Thursday, May 13, 2004 - 23:37 GMT It depends on the enclosure. According to Adire,in a sealed enclosure 1-1.5 cu.ft., you can get mechanical Xmax for the Shiva around 200-300 Wrms.
Username: Newb Post Number: 142 Registered: Dec-03
Friday, May 14, 2004 - 07:35 GMT so giving them 600w would be wasting 300w or so to heat production right? i think they had a mpg of the shiva pounding away with 60w, dont know if they were lying or not lol.
Michigan
Post Number: 2901 Registered: Dec-03
Friday, May 14, 2004 - 15:43 GMT depends on the box you're using
Username: Newb Post Number: 146 Registered: Dec-03
Friday, May 14, 2004 - 16:49 GMT sealed boxes would require more wattage than ported?
Username: Pat_l Tucson,
AZ
Post Number: 99 Registered: Apr-04
Friday, May 14, 2004 - 23:31 GMT I would say Kicker
Username: Doexinggts Post Number: 9 Registered: Apr-04
Saturday, May 15, 2004 - 00:16 GMT how about 2 shivas in a .88 cu ft sealed box how many rms should I run it with ? 300 rms each is ok ? or still the 600 reconmended ?
