Important question that needs help!!!!!
Username: Eugenefan04
Il USA
What does "MOSFET" mean and would it cause any problems if a "MOSFET" amp was hooked in in a 1998 Ford Explorer Eddie Bauer Edition?
I am new to the car audio world so help would be much appreciated
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 11823
http://en.wikipedia.org/wiki/MOSFET
Username: The_image_dynamic
San Diego
Post Number: 583
MOSFET stands for metal oxide semiconductor field effect transistor. Memorized that many years ago. It is basically a high output transistor component.
And no it won't hurt anything, it is just a technology used in amps.
Il USA
so whats the difference between a mosfet amp and a regular amp as in like battery to amp hookups?
San Diego
Post Number: 585
None
Username: Nd4spd18
Southeast PA
Post Number: 940
Yeah a MOFSET is a internal component used in amplifiers....
Il USA
much obliged
