10w7 vs. 10 inch l7
Username: Razzeldazzel06
Post Number: 267
my friend just got a 10 inch solo baric l7 hooked up..it sounds pretty good...i got the 10w7 in the prowedge box..will mine sound better then his???is the 10 w7 beter the the 10 L7
Username: Bernymac
Cambodian
Post Number: 2145
Of course the w7 will sound better. I would get w7's over the L7's anyday.
Post Number: 269
how about the alpine type r??
Username: Skibum12189
Cleveland
Post Number: 307
no, doesnt even compare to a l7 and esp not a dub7
Username: Extrmndor3
IF U HEAR ME... I GOT KING K...
Post Number: 3992
first of all u cant compare a w7 to a l7.... and u cant compare a w7 to a type r...
Post Number: 270
thanks for the help, my friend told me that his 1 12 inch sub will still sound better with more sq and more spl then my 10 inch 10w7 and he only paid lik 200 i think for his sub
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 406
the l7 might have more spl but deffently not sq JL is pretty much a sound quality company the w7 is sql
Username: Solobaric4life
Seminole, Al United states
Post Number: 348
loudness-l7
quality-w7
heard both
Username: James1115
Use a simple...
Post Number: 9298
exactly, the W7 will have much better SQ to most. The problem with this argument is that everyone perceives SQ differently. I might have the need for high detail and great transient response while just a loud 50hz burp might sound good to others. If he likes just loud bass and thinks it sounds good then he will argue with you till he is blue in the face because he likes street bass, and has no idea what real SQ and fidelity is. Don't argue just know that your sub is a all around much better sub then his unless you are SPL competing then he will knock your socks off but thats where it starts and stops.
Username: Imalik
Jackson, New Jersey Ocean
Post Number: 119
Nicely said James
Username: Dlavante
Tigard, Or USA
Post Number: 11
sq- W7>L7
L7's sounds like poo imo
Username: James1115
Use a simple...
Post Number: 9312
thanks man:-) I try!
Post Number: 271
how about the cvx's...how does two 10 inch cvx's sealed compare to 1 10w7 sealed???in terms of sq and spl??
Username: Mgbcs
Lincoln, Nebraska
Post Number: 446
if you have your system, why does it matter? you're going back to all the same old qustions!
Post Number: 350
thankyou james lol
Username: Matt12490
California USA
Post Number: 1843
Wow. Wow. Real talk this fool can't stop asking questions about what is better than what. I thought you would be done after you finally purchased something. Why don't you just wait until you get your sub and go compare yourself. And instead of asking questions, give answers!
P.s. I'm not tryin to be an assho1e
Username: James1115
Use a simple...
Post Number: 9371
AMEN^
