Silver Member Username: Nd4spd18Post Number: 230 Registered: Jul-06 | This amp claims to do 4000 watts at 1 ohm. Can anyone tell me if that rating is accurate and is that at 14.4 volts? |
Silver Member Username: HockeyknightSt. Paul, MN Post Number: 736 Registered: Apr-06 | bump i wanna know |
Silver Member Username: Nd4spd18Post Number: 236 Registered: Jul-06 | I would also like to know what it can do at 1 ohm and 12 volts. |
Silver Member Username: The_image_dynamicSan Diego Post Number: 263 Registered: Dec-06 | http://www.audiogearreviews.com/reviews/amplifiers/review-Lanzar_OPTI_4000D.asp |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1187 Registered: Mar-04 | cs&p tested it, but thier power supply choked and they couldn't max the amp at 1 ohm. Anyway -- 14.4v @ 4 ohms, rated at 1600w - tested 2034 @ 2 ohms, rated at 2900w - tested 3026 @ 1 ohm, power supply maxed out at 3516. One user at termpro claims to have measured it at 4200w at 12.0v, and the SS xxx6500D which uses the same board is said to have been measured at 4500 @ 13.5v. |
Silver Member Username: Nd4spd18Post Number: 252 Registered: Jul-06 | Thanks to Brad and Optidriven, thats exactly what I was looking for. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4080 Registered: Dec-05 | i was going to post some info but you got everything you need. |
