New member Username: Kewinn89Grand bay, Alabama Usa Post Number: 1 Registered: Dec-06 | i have a phoenix digital amp on two 12'' kenwood subs! it beats pretty good but is there any other brand u would recommend with 2 kenwood 12s?? |
Gold Member Username: CtmikeCt. Post Number: 2823 Registered: Feb-06 | what would be your budget, power you need (rms), and at what load? ex. 1000wrms @ 2ohm, 1ohm, etc. |
New member Username: Kewinn89Grand bay, Alabama Usa Post Number: 4 Registered: Dec-06 | i don't really know much about this i am just getting into car stereo systems! but, i don't really have a budget! |
Gold Member Username: CtmikeCt. Post Number: 2825 Registered: Feb-06 | don't say you don't have a budget, people will start recommending you amps in the thousands. everyone has a budget. post the vc config. of the subs (are they dual 4ohm, dual 2ohm, etc.) and the rms of each sub. |
New member Username: Kewinn89Grand bay, Alabama Usa Post Number: 6 Registered: Dec-06 | there 1000 watts peak power! 200rms i'm not sure about the ohms! |
Gold Member Username: MixneffectOrangevale, Ca. USA Post Number: 1323 Registered: Apr-05 | Kevin, Read this; www.bcae1.com If you wanna learn, you will get a lot from this website. ![]() |
