Silver Member Username: Reef
Post Number: 407 Registered: Oct-05
Posted on How much will it help if i udgrade to better speaker wire?? and wat kind should i get? |
Silver Member Username: Livin_loud
Post Number: 517 Registered: Jan-06
Posted on depends on what you're running now and what it's requirements are. doesn't matter too much the kind, as long as its big enough |
Gold Member Username: Stnorris
Davenport,
IA
US
Post Number: 1737 Registered: Apr-06
Posted on 12 gauge will work if your running up to like 1000rms - 1200rms. if you get up like to 1700rms i would do 10 gauge and llower |
