Upgrading SS Rl-P Vs. FI
Username: Brynm
Prince Albert, SK Canada
Post Number: 223
I'm looking to bump up a few categories as far as subs go (right now it's two infinity 1230's) And I'm looking into either a SoundSplinter Rl-P or either an FI Q or a SSD. I have about 2.5 cu. ft. to play with for box size, and am looking at about 1200-1500 watts rms to run it. What are your suggestions? Looking For SQL. also what's the advantage of the flat wind coil and copper coil on the SSD?
Username: Basshead86
Try Google
Post Number: 8114
flat wind can handle a bit more power, and copper is more "sensitive" making the driver sound better while not losing any power handling:-)
i would get a Q, but you don't have a lot of room if you are wanting to go ported.
Username: Adam_s
Sound Splinter, RL-p 15 D4 2.5 Cuft @ 3...
Post Number: 328
if you are planning on using that much power I would say the Rl-p is out because I talked to mike the owner of soundsplinter and he said the 1200 would be the most he would recommend to the RL-p
