Silver Member Username: Volfenhagking1600Atlanta, Georgia USA Post Number: 131 Registered: Oct-06 | How come when i play a 50 hz test tone on my subs its really loud but when i play songs it really aint impressive at all |
Gold Member Username: Thomas_gNM Post Number: 1964 Registered: Oct-05 | whats ur box tuned to, and wut kind of car do u got?? |
Bronze Member Username: BoomtankPost Number: 70 Registered: Oct-06 | And what subs do u have and what songs sound quiet? |
Silver Member Username: Volfenhagking1600Atlanta, Georgia USA Post Number: 132 Registered: Oct-06 | i dk what its tuned to but the port is width-2 7/8" Depth-13" Height-12 1/4" this is my boxhttp://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/2177687/vpcsid/0 /SFV/30046/sret/2141921021721221918281220221282213224229286223288219224221294235 236241242233226239238233238247 |
Silver Member Username: Volfenhagking1600Atlanta, Georgia USA Post Number: 133 Registered: Oct-06 | i have 2 ZX-4812DVX - i had them in a smaller ported box 1.25 each chamber and they sounded alot louder but it was a little too small acoording to the owners manuel |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3671 Registered: Mar-04 | you box is prolly tuned around 45hz. (if prebuilt) try a new box tuned to ~35hz. |
Silver Member Username: Volfenhagking1600Atlanta, Georgia USA Post Number: 134 Registered: Oct-06 | is there any way i can modify the box to make it 35 hz |
Silver Member Username: Volfenhagking1600Atlanta, Georgia USA Post Number: 135 Registered: Oct-06 | this is the box i had before but it was a little bit too small...doesnt polyfill make the subs think its playing in more air?http://www.cardomain.com/item/QLCQLH12512DS |
Bronze Member Username: BoomtankPost Number: 80 Registered: Oct-06 | Yes, slightly dampens and makes box "bigger" |
Silver Member Username: Volfenhagking1600Atlanta, Georgia USA Post Number: 136 Registered: Oct-06 | how big does it actually make the subs think like .10 cu ft or what |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3678 Registered: Mar-04 | you would be MUCH better off just building a new box. your enclosure IS your bass. |
Gold Member Username: Basshead86Try Google Post Number: 8148 Registered: Aug-05 | i posted in the other one. |
