2 15'' Q's with a 2400 watt EXILE amp????????
Username: Avirex64
Vallejo, CA United States
Post Number: 107
Has anyone heard of Exile? It made by phoenix gold but I guess it is alot better. Im thinking of gettin 2 15'' Q's with a X2400.1 amp, its rms is 2400 watts at 1 ohm. Do you think this will over power the Q's?????????
Username: Extrmndor3
Chicago, Ill Us
Post Number: 2393
exile a lot better??? hell no, no build quality can match phoenix gold even that they share the same warehouse, yes exile its like phoenix gold the top of the line woofer of them its juzzz like the xenon but without the raw looks, but basically they are pretty much the same, exile its juzz like discting and crossfire, they both are made by crossfire but distic audio cant match crossfire build quality .
Username: Avirex64
Post Number: 108
do you think this amp will over power the Q's????
Username: Avirex64
Post Number: 114
Username: Livin_loud
Ny
Post Number: 377
They'll eat that amp
