What amp to use
Username: Nd4spd18
Post Number: 59
Since my thread disappeared, I'll post this again.
I am planning to get 2 DD 3515's and a Rockford Fosgate T30001bd amp. The amp costs $900, so what I want to know is are there any 3200 watt amps out there that are as good or better than the Rockford, for the same price or less.
Any suggestions are appreciated, I just want to make sure I am getting the best deal, thanks.
Username: Stnorris
IA US
Post Number: 1453
i dont know of any right now, but im sure you can find somethin cheaper. i bet the massive audio p3000 will put out just as much as that amp, and you could get it for like 700 i think.
Username: Cenus
4, 2 0
Post Number: 2361
that RF amp is very underrated, i've heared them putting out around 38-3900wrms.
Username: Stnorris
IA US
Post Number: 1456
i always hear those amps are overrated. ive heard that when they do the benching they do like max hold on the amp...not positive though
Username: Rovin
Trinidad & T...
Post Number: 9315
soundstream 3500d is around 700 but i would prefer the RF amp .........
Username: Nd4spd18
Post Number: 61
How is the quality of Soundstream amps compared to RF?
And do they produce their rated power?
Username: Drsmith
Montana USA
Post Number: 1275
RF p00ps all over the Soundstream in quality, the RF's are way under rated but i think the SS do there rated power
Username: Nd4spd18
Post Number: 62
but is Soundstream's quality decent, I mean would that amp be worthy of being paired with DD subs?
Also, any other amp suggestions?
Username: Drsmith
Montana USA
Post Number: 1281
i would buy an SS if i needed it, i was just sayin that RF makes some very nice amps and SS just isnt that great, there ok though, go for it i'm sure its a ton cheaper than that RF
talk to ben from www.low-hz.com he sells SS and he is a great guy to deal with
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2882
i'm with rovin, but you loose some quality.
Rockford is better
Username: Loudon
Post Number: 594
with the right electrical kicker zx2500 will do close to 3000
Username: Nd4spd18
Post Number: 64
Ok, but does anyone know for sure if the SS amps do their rated power?
I was reading the specs for the pca3500d and it says "Accepts up to 16VDC power input"; does that mean those power ratings are at 16 volts?
Username: Renegadesrun
Lafayette, IN US
Post Number: 350
eD
Username: Basshead86
Try Google
Post Number: 6952
LMAO^^^^
i love you man!:-)
