Like
I need some help wiring my neon's to my subs
irocz28
where would i hook up the neon's to get them to pulse with the bass of the song? i got amps and subs so which do i hook it to and where at?
Username: Pat_l
Tucson, AZ USA
Post Number: 146
Neon's dont really have anything to do with hooking anything into the car audio system. Neons- if you look closely (and if they have the pulse option) they will have a very thin steel wire going the length of the floresent bulb. As the music creates vibration the steel wire shakes. Once the wire hits the blub the light goes on (completing the circut) so each time the subs thump the wire vibrates against the bulb illuminating it. This is for cheap neons. Some may have audio inputs which would most likley go to the AMP. Look closley at your neon!
Facebook
Shop Related Deals
Directory
