Box building
Username: Crayola0
Wisconsin
Post Number: 382
Is there a way to make ur own terminal on a sub box? cuase i dont to buy one and i dont want to have wire comin out of the port.
Username: Rovin
Trinidad & T...
Post Number: 8739
yep - use a bolt & nut
drill a hole & attach ur wire on either side of this bolt/nut
termianls r so cheap anyway so y u wanna going through this trouble .....
Username: Crayola0
Wisconsin
Post Number: 383
idk i was just wonderin.
Username: Riskyb
Post Number: 21
Its easier to drill a hole just big enough for the wires to fit through. Then tie a knot on the inside and finish it off with some caulk to make it airtight.
