Gold Member Username: Thomas_gNM Post Number: 1441 Registered: Oct-05 | When makin an enclosure with out usin tha subwoofer toolz calculator, if ur gonna use pvc do u put the internal volume excluding the net displacement of the sub or subs?? And how do u tune a box for 2 subs in the same chamber with pvc?? Thanx. |
Gold Member Username: Thomas_gNM Post Number: 1442 Registered: Oct-05 | My bad double post computer fu*k up, B U M P??? |
Gold Member Username: Thomas_gNM Post Number: 1443 Registered: Oct-05 | Plez bump?? |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4520 Registered: Oct-05 | you tune a box for 2 subs in common chamber like you tune a box with one sub. its just with two subs you got more displacement. |
Gold Member Username: Thomas_gNM Post Number: 1444 Registered: Oct-05 | So does this sound right for 2 12s with like around 4cubes with a port 4" wide and like 4.5" long to tune to like around 32hz-33hz?? That port seemz kinda small for 2 subs. Thanx |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4531 Registered: Oct-05 | you can have 2 ports. so you will need 2 4 inch ports that are 13.61 inches long each. you might have to use an elbow cause its kinda long. if you increase cuft of the box then the port can be shorter. |
Gold Member Username: Thomas_gNM Post Number: 1445 Registered: Oct-05 | kool hey chad my computer caught a virus and thats why i was gone for a couple of weeks cuz we needed to take it in to erase everything and then reinstall everything but i had all the box calculators from subwoofer tools to the12volt bookmarked but i need the one that tells you how big if ur gonna do more then 1 port i think its car stereo but not sure, could u give me a link?? Thanx man. ![]() |
Silver Member Username: Crayola0Wisconsin Post Number: 358 Registered: Jun-06 | is this what ur looking for http://www.carstereo.com/help/Articles.cfm?id=31 |
Gold Member Username: Thomas_gNM Post Number: 1446 Registered: Oct-05 | Hell ya thanx dawg. ![]() |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4532 Registered: Oct-05 | lol it would of been easy for me to just give the link. i can be an idiot sometimes. only sometimes. its very rare though. |
Silver Member Username: Crayola0Wisconsin Post Number: 361 Registered: Jun-06 | no problem tj |
Gold Member Username: Thomas_gNM Post Number: 1447 Registered: Oct-05 | lol itz kool |
Bronze Member Username: Pctrailsrider00Loveland, Co USA Post Number: 12 Registered: Jul-06 | www.the12volt.com tune your box to whatever hertz you want using the box calculator. |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4537 Registered: Oct-05 | if you want to get the length for flared ports then you can use this site. its very plain but useful. http://psp-inc.com/psp-inc.com/public_html/..%5Ccgi-bin%5Cport_length_calculator .cgi |
