Any opinions????
Username: 98auroradkm
Post Number: 14
I got these subs and their each 800 rms. I got an 1800 watt amp but its only 900 rms, I was wondering would this be sufficient power for those subs and would it sound good?
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 504
what make/model are the subs and amp
Post Number: 15
The subs are audiobahn alum 10q's and amp is a kenwood 9152
Post Number: 505
whats the voice coil convig on the subs
Post Number: 16
3" dual voice coil
Post Number: 20
anybody????
Username: Carguy
Post Number: 5602
Are your subs 4ohms/3ohms/2ohms DVC? What is the lowest ohms your amp will handle?
As for power, 900w rms should give you adequate bass, but don't expect greast SQ. For that you need different type of subs.
Post Number: 21
6ohms, and the amp is 1 ohm stable
