Ok, my little crappy system is ok, but I want something better than alphasonik and visonik. I'm looking to spend around $300. Here's what I've come up with by looking around these forums.
2-10 inch AA Assassins $140+shippping.approx $175 1-Audiobahn a8000t amp $110+shipping.approx $130 1-Box made by self out of MDF.havent checked price yet 1-1000watt amp kit (wal-mart)..about $20, I think. and of course self install=$0
ya most likely the 12's will take more power, but you've got plenty, and the 12's have a 2db higher sensitvity, so you'll be gaining 4db's by getting the 12's instead of the 10's no matter what amp is used.
The wire kit might be cheap... but if possible, try to get a large gauge (4) - you'll make your life easier if you plan to upgrade later, you won't have to run all the wire again. Just a thought. Other than that, sounds good for only a 300 dollar budget, keep bumpin'
