Question just for the experienced. Know its not the amp forum i always get the answer i want here.
Username: Thebufromnc
Rockwell, NC
Post Number: 83
how do you modify an amplifier to run at 1/2 ohm, and what does this help in if you do it. I got a decent amp right now that's a Directed Audio Viper 1200.1d and it is 1ohm stable. does modifying the amplifier to hold 1/2ohm increase the rms of the amp or what. what would this actually help with modifying it to run 1/2ohm, and do it safely. this is just a curious questin i've been wondering. thanks for the help guys.
Username: Sw9152
Michigan
Post Number: 863
you could run the amp at 1/2 ohm right now it would just heat up quickly. you could do like 30 sec burps at 1/2 and daily driving use it at 1 ohm.
Username: Rovin
Trinidad & T...
Post Number: 8555
go read www.bcae1.com - they have a whole section explaining this
u can "mod" ur amp but it will shorten its lifespan - so there4 what good will it be 2 go through all that mess .........
