Bass tubes
Username: Dirtypimpsmackaho
a buddie of mine told me that all i could fit in my single cab truck was probably a bass tube
what are the best ones
price don't matter
Username: Illuminator
Post Number: 3426
Your buddy is a liar! You should buy a cheap Bazooka sub and beat him to death with it!
Username: Matt12490
Benicia, California USA
Post Number: 1113
hahaha
where do you plan to put the subs? behind the seat? under the seat?? how much room do you have to work with?
Los Angeles, CA USA
Post Number: 4310
lol jexx.
there are no best bass tubes. there are just bass tubes. i think you should be able to find a shallow mount sub with a small box which would sound a whole lot better than any tube.
Username: Justblaze
St.Louis, MO USA
Post Number: 44
or you could try to find an emtpy bass tube box and find a high quality 8 inch sub to put in it. that should at least sound better then a bazooka tube.
Username: Freezeman_7
Post Number: 144
that or get some premier shallow mount tens... with about 3 1/2 inch of mounting depth
Username: Killer44
Ontario Canada
Post Number: 571
http://www.cardomain.com/ride/2403522
no bass tubes there...lol
Los Angeles, CA USA
Post Number: 4332
thats tight killer. did you build that yourself?
i like that box/amp rack. that is your amp in the middle of the two subs right?
Username: Killer44
Ontario Canada
Post Number: 574
ya...me and my dad built it it took us the whole day to build my box and the jeep box on my page (10am-10pm) and shes still not covered gotta buy some black vinyl and diamond plate for it some time soon, its gunna be sick, ive only got it to hit 126 rite now (volume 30/40, and sub level @ 0db/+6db) but thats only with a crappy sosche meter from walmart....but thanx for the props on the setup ill repost my site when i got the infinity's and the alpine amp in...
