Treo tsx 10"
Username: Homercleeze
Post Number: 12
ive decided to throw a little more money into my radio at work, so im gettin rid of the MTX thunder 420 D that im usin now, my question is, would a brutus 600x1 be powerful enough to power the treo im currently using? any help would be appreciated.
Username: Stnorris
Eldridge, IA US
Post Number: 807
i dont think so. if the amp did a true 600rms than yeah. but i htink it will only do like 500rms or so. i would say that sub needs around 700rms - 800rms. try getting an a8000t or somethin.
i know its twice the rms, but they can take it.
Post Number: 13
thanks steve, ive heard audiobahn amps are also overrated though, would you say it gives the full 800 by 2? also i forgot to mention its DVC 4 ohm if it makes a difference
Username: Stnorris
Eldridge, IA US
Post Number: 815
a dvc 4 ohm sub will run @ 2 ohms which is perfect for the a8000t.
no the a8000t is not overrated. it puts out the 800rms. it has been tested........
it will do 800rms @ 2 ohms, and it isnt 1 ohm stable.
Username: Frkkevin
Denton, Texas US
Post Number: 262
I've got an amp I'm trying to get rid of that does 1000rms @ 2ohm on 12volts.. only ran 2 weeks at half power but I need one to do 1000rms @ 1ohm
