Bronze Member Username: Mrmoneymachine8Post Number: 16 Registered: Apr-05 | theres an audiobahn amp. i think its the A8000T or something like that...it says 800 watts RMS @ 2 ohms...i have a kicker L7 12 ". i was wondering if anybody knew if it is an alright amp for the job? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1105 Registered: Dec-05 | yes, if your sub is dual 4 ohm. |
Bronze Member Username: Mrmoneymachine8Post Number: 17 Registered: Apr-05 | does anyone have any personal experiences with the amp? there are no customer reviews on the internet for it |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 2025 Registered: Oct-05 | there are tons of customer reviews... do a search at the top of this page it says "search" and shows a mignifying glass next to it. search for a8000t and you will get some threads that say a ton about it. |
Bronze Member Username: Mrmoneymachine8Post Number: 20 Registered: Apr-05 | well, bass, what do you know about it? i guess its A/b power rated or whatever. whats the difference between that and mono block |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 2029 Registered: Oct-05 | its a great budget amp. like i said, if you do a search for threads like this one, you will find tons of reviews |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1114 Registered: Dec-05 | www.bcae1.com read is a class D |
Bronze Member Username: Mrmoneymachine8Post Number: 21 Registered: Apr-05 | http://www.cardomain.com/item/ABNA8000T juliob, its an A/B mosfet power supply. look at the details. its not a class D. |
Silver Member Username: StnorrisEldridge, IA US Post Number: 508 Registered: Apr-06 | lol juliob. its definanly an A/B. i have one. its a great amp. Derek, it does a true 800rms, and is reliable. ive had no problems with it. really good amp. |
Silver Member Username: ShmanGrandville, Michigan United States Post Number: 264 Registered: Mar-06 | ^^^ i second that.....excellent amp |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1137 Registered: Dec-05 | chauncey brown said it was a class D once, he's an expert, i know the specs say is A/B, but who can argue with an expert? |
