Treo help
Username: Cocizzie
Bakersfield, Cali.
Post Number: 32
ok i pretty much had my mind made up,but know i have second thoughts.i have a pair of dual 4ohm treo ssi's 750 wrms and i have a xx hercules amp which is 2000 wrms @1ohm and 1600 wrms @2ohms,so what will be better?keep the 4ohm and give them a 1000 watts a piece or trade for the 2ohm and give them 800 watts a piece,and is there a noticeable diferrance between 2000 and 1600 wrms.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1000
stay with the hercules
Los Angeles, CA USA
Post Number: 4191
^^^^^what he said.
i am giving my ssi's 1000wrms a piece and its asking for more.
Username: Cocizzie
Bakersfield, Cali.
Post Number: 33
no i havent hooked them up yet,what im asking is, should i run my subs at 1ohm or 2ohm.my subs are 750wrms and at 1ohm ill be giving them 1000 watts a piece and at 2ohm ill be giving them 800 watts a piece.which is better?can they handle 250 more watts running at 1ohm or shall i play it safe and only give them only 50 more watts extra running them at 2ohms
Username: Skies
Courtenay, British Colu... Canada
Post Number: 186
they can handle it
they're true rms is probably around 1000watts
Username: J_baby15
Kentucky
Post Number: 396
Hes sayin should he bridge his amp to 1ohm or run it at 2ohm stereo.
I would run it at 1ohm bridged...wat kinda box u using? Props on da SSIs I like mine.
Username: Cocizzie
Bakersfield, Cali.
Post Number: 34
ported tuned to 32hz
