Sealed or Ported = Type R Loudness
Username: Aman2005
Post Number: 133
PLease please any one tell me the dimensions for the enclosure of Two Type R.. to get a maximum loudness and a reasonable SQ.
Please don't forget to tell me how to tune a box. I am a newbie. If you are going help me, help me in detail
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 474
ported box what size type rs?
Username: Aman2005
Post Number: 134
Hi SPD, thanx for ur suggestion. I've two 10" type r's 4 + 4 ohm Dvc SWR 1042D
Hope to get help from you
Post Number: 475
http://i6.tinypic.com/14 http://i6.tinypic.com/1442q6s.jpg42pux.jpg http://i6.tinypic.com/1442q9t.jpg http://i5.tinypic.com/1442q12.jpg if u want that box cut 2 30x23 2 23x9.5 1 9.5x28.5 1 11x30 1 divider 9.5x21.25 ports 2 9.5x20 or build a box big as u can fit
Post Number: 476
here 2 top bottom 30x23 2 sides 23x9.5 1 front 11x30 1 divder 9.5x22.25 1 back 9.5x28.5 2 ports 20x9.5 it goes top bottom first then both sides but sides on top on the top an bottom then put both sides on then put bac on then ports in then the front an its done
Username: Adddisorder
West palm, Florida
Post Number: 351
search around on some box building sites (google) make each chamber the size that alpine recomends for that sub being ported. youll probly want it tuned 32-35hz
Username: Aman2005
Post Number: 135
SPD,
thanks for telling the dimensions, But I could not understand how to make the port.
Please clarify
Username: Aman2005
Post Number: 136
I tried those dimension and tried to draw a sketch on the paper. But couldnt understand. If you've time, can you please give me a complete procedure and tell me that which dimension is for which side. If possible a diagrmatic representation will be appreciated
Post Number: 483
2 sides 23x9.5 1 divider 9.5x22.25 1 back 9.5x28.5 1 top 1 bottom 30x23 1 front 11x30 2 ports 20x9.5 front gos on last it gos liek 2 sides an divder on the top an bottom then bac an then once its all 2geather with the box open from the front make 4 2 inch spaces put them on 1 side box upwards an take the port an lay it on top of spacers an screw it an then do other side once thats done put the front on
Post Number: 485
aim me @ shadylimitedx
Username: Aman2005
Post Number: 137
SPD, do you have any yahoo id? SO we can talk there?
Username: Aman2005
Post Number: 138
Can you please make a diagram for me to follow the instructions for making a box?
I am unable to understand the measurements, If I cut the wood as yousuggested the size, how will I build the box
Username: Aman2005
Post Number: 139
Can any one upload a skect or diagram for two type r subs 10 " round DVC 4ohm? tuned at 32 - 35 hz for maximum loudness, if possbile, a tuning frequency for maximum loudness and reasonable SQ.
]Please I am a newbie, please help me out!!!
West palm, Florida
Post Number: 380
search on google, most people here dont have time to compleatly walk you threw your entire install with every little detail
Username: Aman2005
Post Number: 140
dope, I did the search on google, but couldnt find anything. If people dont have time, why they are here to help others??
They are spending their free time here because they want to tell others about their passion and knowledge
