Is this amp good to power 2 cvx 12" safely ? The subs are 4 ohms.I just want bass and some sq very littel of that but you know what i mean.And are the subs going to be over powered.And how do you wire them?
no, that amps only 2ohm stable and you need to wire the pair of subs at 1ohm if your using 1 amp. if you want to stick with kicker i'd get either the 750.1 or at most the 1000.1 for each.
So to wire the subs like that you have to have a amp that is 1 ohm? And when it says 4 ohms: 1250 watts x 1 chan that means that it sending that amount to each sub?
