Front door speakers, Recmendation
Username: Bmage29
IA USA
Post Number: 12
Something happened to my previous post, don't know what though. ANYWAYS...
My current speakers are about shot, and I need new ones. I got a comparison from crutchfield.com and need some more opinions. Also is sony any good since it's so cheap?
http://www.crutchfield.com/cgi-bin/prodcomp.asp?g=51800&compareite ms=500SPS130A&compareitems=158XSV1342&compareitems=130TSA1371&compareitems=500SP S13C2&compareitems=109GTO527&compareitems=113KFC1390&hidesimilar=y
I want the speakers to merely replace my factory ones, without adding an extra amp or extra wiring. Crutchfield says they send addaptors for factory settings.
Recommendations would be appreciated.
ALSO NOT SPENDING OVER $100 for speakers, I might replace my rear speakers, but they are still in fairly good shape.
Username: Bmage29
IA USA
Post Number: 13
P.S. also, when searching the site, I used the "Find what fits my car feature" for reference.
These are all 5 1/4 in. speakers
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2122
Alpine Type S are nice coaxial replacements. Boston Acoustics also makes some nice Coaxials.
Username: Bmage29
IA USA
Post Number: 18
Thanks, anyone else. Would like to get as many opinions as possible!
Username: Muchlouderthanu
If you want to get an amazing pair of speakers go with the MB Quart Q series line. Either the QSDs or the QSCs. I just got the QSDs and they are the best speaker you can get on the market right now other than Focal. I has the alpine type Rs before these and the MB Quarts blow them out of the water.
Username: Adddisorder
West palm, Florida
Post Number: 326
alpine type s
Username: Dkchillin
Vermont
Post Number: 87
Of the ones in your comparison I'd also go with the Type S, but you may also want to think about a set of Polk db525's. They're $89.99 on Crutchfield and you can get them cheaper on ebay (here is an auction going on now). I run the component version (db5250) and am very happy with them.
Keep in mind though that we can give you all the advice in the world, but the best thing to do is go out and listen for yourself. I listened to the Type S as well as many others (Infinity, MTX, Pioneer, Kenwood) and settled on the Polk speakers simply based on my personal preference. You're not going to find a lot of tangible difference in terms of quality and materials if you stick to major brands in a similar price range, so it comes down to which ones sound best to you.
