Like
Amp for arsenal???
Username: Splmonster
Post Number: 66
whats a good amp for the 15 arsenal it has 750 wrms some people said the ed nine.1 and the orion 1200d is that to many watts for this sub,i kinda wanna get the best amp for it but best for the money cuz moneys tight since i bought the arsenal
Username: Suleman36
Maryland U.S.A.
Post Number: 3734
JL 500/1 is a great choice
Orion 600D
Kicker KX600.1
MTX Audio Thunder TA5601
Username: Suleman36
Maryland U.S.A.
Post Number: 3735
I whould get a nine 1 and run it at 900 x 1 @ 2 ohm
That whould be your best bet. You could use that amp down to 1 ohm for later use. $350 shipped / great deal
Post Number: 67
i was thinkin the nine.1 but its on back order so thats a big thing, i think i might just go for one of the ones u said in ur first post, think that'll push it hard enough, because i plan on getting another arsenal and a HO alt in like 5-6 months
Post Number: 68
but all those in ur first post put out like 500 rms or lower, would i just be better getting a good 1000-1200 watt amp, what is a good 1200 watt amp, will the kx 1200.1 work or something else ( would get the nine.1 but its on backorder and i kinda wanna get it asap )
Username: Suleman36
Maryland U.S.A.
Post Number: 3738
In that case, go with the JL 1000/1
Arsenal's are dual 4 ohm voice coil subs which means if you have 2 of them, then your only options are to wire them in series to get a 4 ohm final impedence or down to 1 ohm
The JL 1000/1 can run either 1 of the Arsenals or 2 of them when you get both.
The Orion 1200D puts out 1200 watts rms @ 1 ohm which works well if you have two Arsenals
The Kicker KX1200.1 does 1200 watts rms @ 2 ohm which can only run 1 Arsenal and not 2.
The JL 1000/1 is good from 1.5-4 ohms and is more flexible and built alot better then all the amps mentioned and whould be your best choice if you have the money.
IF not then i whould settle with the Orion 1200D or ED NINE 1
Post Number: 69
alright thanks man
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1775
"The Kicker KX1200.1 does 1200 watts rms @ 2 ohm which can only run 1 Arsenal and not 2."
Um the kx1200.1 is 1ohm stable, the new zx1000.1 is only 2ohm stable, me personally would go with the kicker, but any of the amps MO mentioned would work.
Post Number: 79
u personally would go with wich kicker the 1200 or the 1000?
Username: Cenus
Post Number: 1776
i'd go with the kx1200.1, or if you can find one cheap a sx1250.1.
Post Number: 87
whered be a good place to buy the kx1200.1?? i checked on ebay and no new ones
Username: Suleman36
Maryland U.S.A.
Post Number: 3753
IF the KX1200.1 is 1 ohm stable then it is a good choice aswell. I whould get the Orion 1200D or KX1200.1 or ED NINE 1
Either way it will get the job done.
Post Number: 89
aight, any good sites to get them off of, im prolly just gonna end up getting anyone i can find the cheapest since they are all good
Username: Ctmike
Ct.
Post Number: 557
some kx1200.1's
http://www.speedsound.com/product.asp?specific=jpfripi4
http://carstereoexpo.com/kxki1chcaram1.html
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=269
Post Number: 90
that nine.1 at $350 is looking better and better everytime i look here, it says backorder anyone know how long it takes to ship? if its not to long thats what i'll get
Username: Ctmike
Ct.
Post Number: 572
i've been waiting for the nine.1's for my arsenals to and i was told by ed that it'll be 3-4 weeks until there back in stock, and i was told that on may 4th.
Post Number: 93
didnt see your post and i called them they said like 4-5 weeks, thats to long i gotta find something quick
Post Number: 94
u think if i got a orion 600d it would be really underpowering it??
Username: Suleman36
Maryland U.S.A.
Post Number: 3759
you keep asking the same questions man. You need a 1200D if your going to power 2 of them. If your only going to power 1 then just get a Kicker KX600.1 or somthing.
Post Number: 96
lol sorry but i just dont understand, im just going for one for now, but the kx600 puts out 300rms and the arsenal is like 750 rms so i guess ill just get the kx600 for one
Post Number: 97
what about this amp?
http://cgi.ebay.com/BRUTUS-600-WATT-X-1-RMS-1-OHM-ILLUMINATED-AMP_W0QQitemZ97172 28070QQcategoryZ18797QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
Username: Suleman36
Maryland U.S.A.
Post Number: 3760
The Arsenal is dual 4 ohm which means you can only wire it into 2 ohm or 8 ohm.
That kicker kx600.1 puts out 600 rms @ 2 ohm. Just check it.
Post Number: 98
oh mah bad man i dont really gett the wriring stuff well thanks for straightening me out lol and sorry for asking the same question, and i swear this will be the last one, how should i wire it to 2ohms like that is there any special way?
Username: Suleman36
Maryland U.S.A.
Post Number: 3762
http://www.the12volt.com/caraudio/woofer_configurations.asp
Just select your subwoofer configiration on that page and it will tell you exactly how to do it.
Facebook
Shop Related Deals
Directory
