Alpine Type R's Any good
Username: Reef
Post Number: 33
Do you guys think the type Rs are better than assaissins 12s and CVR 12s? i wanna get a good pair of 12s that sound the best and loudest for under 200$
Username: Ctmike
Ct.
Post Number: 507
r's are really nice when properly powered and in a good ported box, get loud and still sound good. i'd definately choose them over the kickers. the assassins i think sound just as good but just doesn't get as loud. but if you want the best under $200 look at the aa arsenals, i hear there even better than the type r's,
http://ascendantaudio.com/index.html
Username: Extrmndor3
Chicago, Ill Us
Post Number: 668
if your goin for spl go wit these ones
http://cardiscountstereos.com/catalog%20page.asp?Product+%23=AW1208T
forget abou sq wit this ones
if your going wit sql go wit these ones
http://cardiscountstereos.com/catalog%20page.asp?Product+%23=AW1206T
if your goin wit sq go wit assasins
