I have 8ga. power going to the back/Org.I got the wireing packedge for 350 watts if this helps. The amp it is normalily connected to is a SONY 600 watt amp. I currently have 1 12" Sony. peak 1100 watts. My question to you professionals is there anyway i can run a second AMP the same as i have and not be worried about pulling to much power through my power wire causeing it to heat/melt/Fire? Or do i need to be rewired for more watts? Thank You,
my sub is 100watts RMS.. Amp is i think 125watts per channel. this amp is a 3/4 channel amp whatever this means.. Currently i have the SUB pulling from two channels.
8ga is TINY! I have used that as sub wire and NOT power wire before! You will need to upgrade your wire size runing from the front to the back, with a new fuse to protect that wire! Atleast 4ga wire!
Could i just wire it for 1000 RMS from a new car batt. in the trunk, instead of running a whole new power the length of the car?. I wanted to mabye just jump the ground there on the current AMP and also the same for the RCA and remote. Is this at all ok to do?
