IDmax vs. Eclipse TI
Username: Mateo
Post Number: 84
i was looking at a 12" IDMax and a 15" Eclipse TI. what do you guys think....i can get both for the same price...give or take $5. thanks
Username: Sw9152
Michigan
Post Number: 515
i have not heard the idmax, but i am really happy with my 15" eclipse ti. gets really loud yet staying clean and crisp and the lows are amazing. keep in mind that it is 1500wrms though, not 750 like eclispe-web.com says because they rated them per vc.
Username: Suleman36
Maryland U.S.A.
Post Number: 3644
If you want more more SPL/BASS then go with the 15 Ti ported. If you want more SQ/Bass then go with the ID MAX 12.
Both are great subwoofers but the ID MAX 12 is alot more efficiant and sounds great with 200-1000 watts rms.
Username: Mateo
Post Number: 85
ok thanks alot guys for the quick responses. does anyone else have any opinions?
Username: Suleman36
Maryland U.S.A.
Post Number: 3645
ID MAX 12 ported at 2.5 cuft net @ 30hz is recommended. That is what i plan to go with once the new versian 4 comes out.
Username: Mateo
Post Number: 87
ok ill keep that in mind. thanks
Username: Mateo
Post Number: 88
bump
Username: 420pimp2
Post Number: 672
wouldn't two twelves ported have more bass then 1 15 ti ported?
Username: Mateo
Post Number: 89
i dont want two 12s though. but yea they would have more output because of more surface area
Username: Mateo
Post Number: 91
bump
