Bronze Member Username: AnacardDimond Bar, CA United States Post Number: 21 Registered: Jul-05 | well i was thinking of using a zapco c2k4kw....this will be going in a cadillac ext ...no back seat ...see i was thinking i was of using RE 18 MT... but they say its not a daily driver .... well i have some money to work with... and the only thing i wont change is the 18's ...i have had 10..12...13.5...and 15 never 18 so if any one give any ideas ..i would like to hear ....oh i know i will need a 600 amp alt![]() |
Gold Member Username: B101Queen City, NC USA Post Number: 2772 Registered: Sep-05 | get a single TREO SSX 18.. it will hold its own over the MT and make it look like shhhh... It will need that amp for itself, with about 8-9 cubes... www.treoonline.com |
Silver Member Username: Sw9152Michigan Post Number: 613 Registered: Feb-06 | if you dont need the subs immediately you could wait for the new RE XXX 18" to come out and you could power 2 of them. supposedly they have good sq, but with almost 5" of excursion they have to be extremely loud. |
