New member Username: JakubmanPost Number: 1 Registered: May-06 | Ok im new hear and was wondering if i blew my amp or not.I have a Lighting Audio B250.1.It was working fine till one day i accedently toched the power wire running from my battery to the screw that holds the face plate.It made a huge spark.It was grounded and now it doesnt work.What happened??Thanks |
Silver Member Username: GoatinU.S.A Post Number: 981 Registered: Jan-06 | you blew your power line fuse. Hopefully |
New member Username: JakubmanPost Number: 2 Registered: May-06 | Actually i checked all the fuses and they are all good to go. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6860 Registered: Jul-05 | did u check the fuses in the amp??? |
Silver Member Username: GoatinU.S.A Post Number: 983 Registered: Jan-06 | does it light up? |
New member Username: JakubmanPost Number: 3 Registered: May-06 | Nope i finally gave up and kicked the crap out of it so nevermind.But thanks for heping. |
Bronze Member Username: Emdawg12345Post Number: 37 Registered: Jan-06 | http://www.rotteneggs.com/?refid=182315 lol look |
