Silver Member Username: HockeyknightPost Number: 125 Registered: Apr-06 | anyone know how ma audio amps are??? im lookin for a cheap amp that gets about 800 rms and i found this...http://cgi.ebay.com/MA-AUDIO-HK800-800w-RMS-CAR-AMPLIFIER-AMP-FAN-HK-800D_W0QQit emZ9719104537QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem if not that one how bout a audiobahn... http://cgi.ebay.com/Audiobahn-A8000T-Intake-Mono-Block-1600W-Chrome-Amp-NEW_W0QQ itemZ9719066951QQcategoryZ64571QQssPageNameZWDVWQQrdZ1QQcmdZViewItem do either of these accually put out what they say....??? thanks |
Silver Member Username: HockeyknightPost Number: 129 Registered: Apr-06 | dose any1 know about any other cheap amps that have 800 rms |
Bronze Member Username: _jay_Post Number: 80 Registered: Mar-06 | hmm that ma audio is a referb...and audiobahn isn't that great of a choice..not the worst but close, i would try looking into hifonics....there amps r cheap and u get quite a bit for ur buck...not lyke audiobahn n' be over rated..n' other off brands..but i need 2 know either ur subs 2ohm or 4ohm n' wut voice coil..? but without that i could still give u a hifonics amp ...go 2 ebay put this in the search box 9719609730...that is the item number -JaY |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 572 Registered: Dec-05 | problem with MA is that their stuff are rated at 17 volts, you will need a good electrical upgrade to achieve that, their high end stuff is good, go with hifonics yeah |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 573 Registered: Dec-05 | that audiobahn is great, you will get 800 rms for real |
Silver Member Username: AdddisorderWest palm, Florida Post Number: 208 Registered: Jan-06 | yeah audiobahn does put out its power |
