I have a GM truck, since I the power wire between the inline fuse and battery should be short I am having trouble finding a location to mount the inline fuse box. IS THERE ANY problem with mounting it on top of the battery? WHAT ARE THE DOES AND DONTS when looking for a location for the linline fuse?
personally i didnt mount mine to anything, i dont see why you HAVE to as long as its not going to be getting cought in anything. i wouldnt suggest putting it directly on the battery becasue you might puncture the inside and that wouldnt be good. so if i were you just attatch it to the wire and just let it sit there out of the way
