Subwoofers won't play
Username: Turbovw
I just installed my subwoofers in my new car. they worked for a week then stopped working. I checked all the wiring. The amp is working just not the woofers. Any help would be greatly appreciated
Username: Its_bacon12
Post Number: 532
theres almost no possible way to tell from what you've given us...
i will tell you to take it to a car shop somewhere and ask them to look at it for you (not CC or BB, they will not touch anything they didnt install)
Username: Rswan
Post Number: 27
maybe your rca's became disconnected on your head unit or your wires inside your box came loose. i would check all the connections that send the signal to the speakers
boister77
generally, a simple way to test your subs is to use a 9v battery. if the cone moves, the sub should be alright.
