How do i wire 2 alpine swr-1242 subs for a 1ohm load???
Username: Quick_94gt
i just got these today and want to install them but i have no idea ho to wire them each for a 2ohm load and then i 1ohm load, a diagram would be nice.
mario
Username: Dustin3
Tigard, Or U.S.
Post Number: 544
if those are the dual VC 4 ohm subs. you can wire it like:
Username: Dustin3
Tigard, Or U.S.
Post Number: 545
so you want your vc wired in parallel and your subs wired in parallel also... giving you a 1 ohm load.
Username: Dustin3
Tigard, Or U.S.
Post Number: 546
hope that helps.
