2 xJL w6
Username: Lilaznboi
Post Number: 18
I have 2 12" JL w6 and i'm planning to go buy an amp for these. what kinda amp would be considered to power these subz?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6024
vc configs (dvc 6ohms???)
Username: Lilaznboi
Post Number: 19
12W6v2-D4
Post Number: 6025
budget
Username: Rovin
Trinidad & T...
Post Number: 6527
if u own gr8 subs like that u might as well buy a JL 1000/1 amp ........
Post Number: 6031
or 2 500/1
Username: Redliner
Wilmington, Ma
Post Number: 987
im with either of those^^^^^^^ great amps for great subs
Username: Johnny619
San Diego, CA
Post Number: 70
I use to got a pair of those sub on a JBL bp 1200.1 and it sound pretty good, now ima amp each sub with a JL 500/1
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1357
a 500/1 oneach would be great and hey! i just happen to have 2 for sale, lol
https://www.ecoustics.com/electronics/forum/car-audio/206194.html
5878364236
5878366132
Username: King_1532
Tallahasse, FL United States
Post Number: 9
I personally wouldnt go and buy a JL amp unless you have the cash. But why waste it when you can get just a good of amp if not better for your w6s. They are 400 rms each, I would go with the MBquart RAA1000 and wire it down to 1 ohm. That even gives you some headroom and is cheaper than buying 1 JL 500/1.
Username: Delsole
Post Number: 124
im down wit 2 jl 500/1 or one jl 1000/1
Username: Delsole
Post Number: 125
listen to kingsley but if you got the cash then buy jl becuase you can nevery go wrong buying what jl mostely recomends for there speakers
and nevermingd that they still make some damn good amps
