Bandpass in a 04 mustange?
Username: Shepyjay
Ont Canada
Post Number: 80
bandpass in a 2004 mustange what do u guys think?
any concerns besides building it inside the car
Username: Tjmutlow
Post Number: 1551
no, use a slot ported box instead.
Username: Nemen
Trinidad & Tobago West...
Post Number: 332
those mustangs have small @ss trunks what are you gonna put in there i know in my 96 stang i could only fit two tens.
Username: Shepyjay
Ont Canada
Post Number: 81
i have 2 12 gt120 jbl subs i only have 5.20 cubi feet
to work with i can build a slot ported box but i want to try some thing more difficult to build... also i havent seen a mustange with a custom built bandpass
enclosure
Username: Sploosh56
Ohio
Post Number: 1171
if you're going to go bandpass you should run the ports through the rear deck and into the cabin and seal off the trunk. That way all of your bass is in the cabin of the car and none wasted in the trunk
