Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2102 Registered: Mar-04 | there have been a few people emailing me about how to build boxes w/ interchangable ports. i just finish a box w/ these ports, so i took some pics of the build and made a how-to guide. enjoy. http://www.cardomain.com/ride/650399/6 |
Gold Member Username: 54danny54Betsy layne, Kentucky..GO... USA duh Post Number: 1753 Registered: Nov-04 | yo marshall, i know ur asked this alort but wuts the DB's ur SX hits lol? |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2103 Registered: Mar-04 | after box rise the SX15 sees ~750wrms on burps...i did 148.0db @48hz at the last comp i went to, but i made a few changes to the box...hopfully i'll gain a lil. i have a comp on the 24th...the guy in that how-to guide will be there w/ me too, he will be in SS301-900. i hooked those 2 L5 15's to my jbl bp1200.1 for a lil bit and it was pretty loud. w/ the SPL port in i'm guessing he should be in the high 140s easily. |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 1806 Registered: Sep-04 | you do good work marshal. how long did it take you to build that box? i actually do want to do interchangable ports on my next enclosure. the only thing im worried about is it will be bent like an L and im afraid it wont fit because it wont drop straight in. very good "how to" though. |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2104 Registered: Mar-04 | thanks trevor, and L-shaped drop in port will work just fine...you just have to think it through when you build it. infact...my daily port is L-shaped http://www.cardomain.com/ride/650399/1 |
Gold Member Username: 54danny54Betsy layne, Kentucky..GO... USA duh Post Number: 1754 Registered: Nov-04 | yo trevor...u have had experience with the Ava.. what would u say is the ball park figure of tuning for comps u reccomend at 5 cubes?(i know wierd wording but im stressed cause i corrupted windows and lost every bit of info i had) |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 1808 Registered: Sep-04 | i dont know really. i guess like 45hz-50hz. remember the ava isnt an SPL driver and the higher you go it will begin to dropoff. id find out the cas res. freq. and remember if ur doing interchangable ports your net cuft will change with a different port. |
Gold Member Username: 54danny54Betsy layne, Kentucky..GO... USA duh Post Number: 1755 Registered: Nov-04 | yea i kno...il try 2 experoment |
Gold Member Username: 54danny54Betsy layne, Kentucky..GO... USA duh Post Number: 1757 Registered: Nov-04 | marshall man...u know how to build a box well man, looks complicated |
Silver Member Username: Jprix82Post Number: 130 Registered: Jan-06 | hey marshall how did you figure out the port size? |
Gold Member Username: B101Queen City, NC USA Post Number: 1038 Registered: Sep-05 | looking real good marshall; now you need to start selling them on Ecousticcs! =D |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2106 Registered: Mar-04 | B, if people are willing to buy them...i am more than willing to sell Joseph, i use winISD and a lil geometry is all. its hard to explain in words...but if i had someone watching me build the box, its easier to understand. you just have to factor in port and sub displacments when designing the enclosure. |
Bronze Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 70 Registered: Feb-06 | if u want changable ports all u do is make a big seald box but use pvc pipe ports like say u want 32hz put 2 4inch pvc in it then u want ur cars top fre. then u make 1 for that an w/e else u want but make sure u dont glue it an u can get changin it 2 ur liking thats what iam goin 2 do |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 2121 Registered: Mar-04 | |
Silver Member Username: MixmastaspigCanada, Canada Canada Post Number: 378 Registered: Sep-05 | Sweet deal on the box dude |
Silver Member Username: Jprix82Post Number: 134 Registered: Jan-06 | Anyway nice guide now all you need to make is a guide on how to figure out port sizes lol i know that it would help alot of people. |
