SUBS HELP
Username: Mangle
Lynchburg, VA USA
I have four 4ohm DVC MB Quart subs what is the best way to wire them there are 2 pos and neg terminals on each sub. I will be using a Kenwood KAC9102D to power them with. They are going in a quad enclosure non ported. Will be in the back of a 2004 trailblazer.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5239
U can wire it to a 2 ohm or 8 ohm load, what are the specs on ur amp
Post Number: 5240
http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Mangle
Lynchburg, VA USA
Thanks for the info Chauncey Brown here are the Amp specs
1,700 watts max output Mono amplifier
850 watts RMS @ 2 ohms
2 Ohm stable
500 watts RMS @ 4 ohms
Efficient Class D Circuitry
MOSFET Power Supply
Noise Suppression Filter
Copper Power Transformer
Dual Secondary Caps
Detachable Top Panel for Controls
Die-Cast Alluminum Heat Sink
Advanced Low Pass Crossover
18 dB / Octave Subsonic Filter
Preamp Outputs
High and Low Level Inputs
Screw-Type Power and Speaker Terminals
0-18 dB Bass Boost @ 90 Hz
Single-Side Terminal Placement for a more efficient install
Frequency Response: 5-200 Hz
Signal to Noise Ratio: 100 dB
Dual Cooling Fans
Username: Mangle
Lynchburg, VA USA
This is probably not the best and most high end equipment but I am on a budget. I have almost a total of $400.00 in the box subs and AMP all new stuff. Found a deal and took it I hope it will be good enough for a starter set anyway I will see how it sounds in a week or so.
Username: Rovin
Trinidad & T...
Post Number: 5443
good of u 2 give the amp specs - but where r the specs 4 ur subs !???..............
Username: Mangle
Lynchburg, VA USA
10" Subwoofer
Impedance:4 Ohm DVC
Frequency Response: 16- 300
Sensitivity: 2,8dB
Power Range: 400 Watts
Recommended Box 1 (Vb): 0.65 cu. ft. sealed
