Can i wire three compvr on this amp
Username: Night_mirage
TexasUSA
Post Number: 40
Hi Guys ..
I want to buy three of kicker comp cvr 12" 4ohm .
Can i wire them on SX1250.1
or i have to buy kx2500.1
Thanks ..
TexasUSA
Post Number: 44
Guys Guys
maybe you do not understand what do i mean
Can Sx1250.1 Push three of comp cvr 12" 4ohm ????
please help ?
Username: Chevelle
Lancaster, Pa Usa
Post Number: 43
it will push them but you have to wire all three to one load.Check with kicker or go to there web site and click on support they have speaker info and wireing info
Username: Rovin
Trinidad & T...
Post Number: 5302
Buy a Phoenix Gold Xenon which does 1200wrms between 1-4ohms so u won't have 2 worry about the load it sees ......
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4920
what he said^^
or u can find an amp thats stable at 2 or 1 ohms and u will be fine
Username: Tjmutlow
Post Number: 1349
the 3 comp vrs will only wire down to a 2.666 or 6 ohm load if they are dual 4's
TexasUSA
Post Number: 46
Thanks Guys .
I 'll see about your advices
