Should i build a wall or put box in the trunk?
For my 2 15's Should i build a wall behind the front seats or just put box in the trunk?What would be the difference between the 2 setups?
Username: Insearchofbass
Post Number: 4454
you would more than likely hit more spl with the wall.....cutting the distance in half raises your spl by 3 db .....i put that to the test with my spl meter in my apartment and it was true
Post Number: 4455
another trick is corner loading and that can add as much as 6 db but youd have to experiment with that in the trunk probably for best effect
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 538
what is corner loading?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1719
i believe its like if youve ever noticed if you stand in a corner the bass seems louder. so im guessing you would want to have the most bass build up at mic placement. or if your not competing than head placement lol.
Post Number: 4486
corner loading is when you place the subwoofer in the corner of a room or in this cas a trunk wall and the bass gets reinforced by the wall itself its usually place close to a wall....within inches
Post Number: 4488
and you fire the subwoofer toward the wall
Username: Suleman36
Maryland U.S.A.
Post Number: 2969
sean, how are you liking your spl meter. Having fun with it.
Post Number: 4489
there is another technic called slot loading and that is using two subwoofers facing each other a specfied distance apart and it has to do with the waves compressing and releasing for a greater spl effect
Post Number: 4490
ive only used it once so far but it seems to fit the bill
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 543
for slot loading i wonder how far apart you would want 2 12"'s?
Post Number: 4543
all ive been told is its trial and error you have to find the distance it takes
Username: Spyder
Eglin AFB, Florida USA
Post Number: 282
and you have to have exact power going towards each sub or one will throw the other sub out of wack.....from what i have been told atleast.....the guys i asked about it said you can blow the subs doing it but if you get it just right the outcome is ungodly loud!
