Why can I not sound deaden my car?
Username: Iufan4lifeul
Post Number: 872
It is still rattling like crazy. Mainly just the trunk (I have a Mitsubishi Lancer with 2 RE12's and 500rms total to them). I have 2 layers of the eDead v2 lining my trunk lid and it still vibrates like a mofo. Thing is, I didn't use one of those rolly things to press it down so some might not be ALL the way on but instead most of the way on. I also have to use some of that spray on glue stuff to get certain parts to stick. What can I do to fix the rattling problem? I guess I might order another 30sq. feet.
Is it the metal of the trunk vibrating or the actual trunk vibrating against the rest of the car?
Username: Celica150db
Australia
Post Number: 43
got an idea!
turn up the volume and check to see that its not the number plate or anythink else outside the car!
Username: Tjmutlow
Post Number: 1310
hate to tell you, your not going to get all rattling out.... unless you take the subs out....
Australia
Post Number: 45
^^^^could you not get all your rattle's out???
you should never give up!!
didn't your mum tell you that??
Username: Shadylimitedx
Pgh, Pa Usa
Post Number: 501
my car better not rattle i did the whole car in fat mat trunk lid, trunk, floor, roof, sides an doors an its all on the metal cause i used the roller hope it dosnt rattle iam goin 2 test it when i get the trunk done
Australia
Post Number: 49
alright we have someone that dont quite!
nice to see!
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 564
well i have my trunk fully lined w/ dynamat extreme and some spots 2 and 3 layers and my trunk doesn't rattle that much unless i turn it up really loud and i have 3 jl 12w3v2's. I used to have a lancer and i lined the trunk lid w/ dynamat extreme and then the tire well and trunk floor w/ original dynamat and the sides w/ extreme and my trunk didn't rattle that much and in the lancer i had 2 10's and a 15. maybe some of this other sound deadening stuff doesn't work as good as dynamat. just my thoughts
Username: Alteraudiousa
Concord
Post Number: 107
you need to deaden the entire trunk, sidewalls, speare tirewell. Pull up the carpet and deaded any metal you see.
Pgh, Pa Usa
Post Number: 518
i hear that fat mat is just the same as dynamat but cheaper
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2032
2 words:
---expanding foam---
nuff said.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10887
the mat will (when applied properly) reduce the resonance inside the trunk. It won't stop the sheet metal outside from resonating though. Also if you only did the trunk lid, you still have the whole rest of the trunk to resonate as well.
expanding spray foam and products like "Sludge" do wonders to help reduce resonance in areas you can't easily mat.
It's just a matter of thoroughly deadening everything you can.
Username: Insearchofbass
Post Number: 4548
glasswolf would lining the whole trunk in wood airtight work just as well im curious what you think the trunk lid would be lined too
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10893
no.
the metal will still resonate.
you need to actually alter the sympathetic frequency of the metal, and you only do that by altering the density or constitution of the material.
Pgh, Pa Usa
Post Number: 522
Pgh, Pa Usa
Post Number: 523
Post Number: 4559
nice work scott
Pgh, Pa Usa
Post Number: 524
Pgh, Pa Usa
Post Number: 525
tolk a month so far but i havnt been doin it every day tho an its cold an it sucks lol so u think my bass b nice lol
Post Number: 4560
should definately help the sound quality and hopefully spl
Pgh, Pa Usa
Post Number: 529
u think about 3db cause ppl say if u use sound dampin u can gain atlease 3db an 2day i think iam goin 2 get the cars fre. of a 93 firebird hatchbac got the cd seald box an amp think iam goin 2 have 2 sit the box on the flod down set facin the bac so if u get on aim im me casue i might need a lil more help
Post Number: 4564
it might but not all cars gain 3 db
Pgh, Pa Usa
Post Number: 530
b4 i did this all i threw in a 30hz portd box an the only thing that rattle was the trunk lid but not that much
