don't invert them, lol. you'll have to keep some kind of oil/polish compound on them to keep the moisture off. don't really know a particular product to tell you though. never really heard anyone with this problem before.
ahhhh. i was under the impression they were inside the box. you may try wd-40. you would need some type of oil polish to keep they moisture free like brandon said.
thanks dudes. but nothing as for taking oxidation off? think soda or sodium peroxide will do it? i hope sodium peroxide won't PROMOTE oxidation lol. so i'll hold off until i'm sure.
Limerust? I'm pretty sure the product is like CRL or something, Calcuim, Rust, Lime. Peroxide is an oxidant, so it probably will promote it. I'd not do that.
