New member Username: Jp1981Dallas , Tx Usa Post Number: 1 Registered: Jan-06 | I recentley bought two MTX 8500 series subwoofers they are about 900-1100 watts each. I need to know how to hook up two mono amplifiers, how do i get power to them and how do they hook up to the head unit (remote wire,output and input wires) please don't spare any details. Or what kind of 2 channel amp is out there that handle both the speakers? |
Silver Member Username: BrynmPrince Albert, SK Canada Post Number: 164 Registered: Jul-05 | what's your budgetand what are the voice coil configs? |
New member Username: Jp1981Dallas , Tx Usa Post Number: 2 Registered: Jan-06 | 3" high temp voice coils 428°F Voice Coil Wire Temp Rating. And my budget can get can go eaither way but the less money i spend the better. thanks bro. |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 373 Registered: Mar-04 | http://www.bcae1.com/amplfier.htm |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 374 Registered: Mar-04 | The 8500's are either dual 4 ohm coils or single. That's the info we need. Also - the 10's and 12's are 500w rms, the 15's are 600w. The most logical way to power them would be with one mono amp that's 1000-1200w at 1 or 2 ohms - depending on whether you have svc's or dvc's. |
New member Username: Jp1981Dallas , Tx Usa Post Number: 3 Registered: Jan-06 | My 8500's are single coil. |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 388 Registered: Mar-04 | you're looking for a mono amp around 1200w at 2 ohms. |
Gold Member Username: InsearchofbassPost Number: 4354 Registered: Jun-04 | my amp here is for sale https://www.ecoustics.com/electronics/forum/car-audio/192406.html |
Gold Member Username: InsearchofbassPost Number: 4355 Registered: Jun-04 | i had the 8000 mtx 10's trust me they handled more than the 400 rms each |
