Small sealed enclosure?
jay jay
whats the best 12" subs for a small sealed enclosure. about .88 cubic ft. i am thinkin about gettin two polk mm1242's. i know i wont be able to fit some huge TI'sor anything but lookin for some thump. any suggestions? price range is anywhere up to $550.
Username: A444w444m
Post Number: 181
is that the total amnt for your whole system or just the subs? also, register and u might get some more responses
Username: Phuktupbasshead
Scottsdale, Arizona United State...
Post Number: 360
let's see...
you got
Image Dynamics IDMAX
Alpine Type R's
Power Acoustik FUBR (not a high end sub BUT does get loud)
Eclipse Ti's are optimized for sealed - not sure of size though
i've been doing alot of research on that question...but i can't seem to remember right now off the top of my head.
s,h,i,t! that's all for now, I guess.
anybody else?
jay jay
i only have 6.875" of mounting depth which kind of narrows down my selection.
Username: Symplestiles
Stockton, CA Usa
Post Number: 387
i know cerwin vega VMAXs require about 1cuft of space but if you put some polyfil in that .88cuft box youll be ok. compVRs and infinity perfects also dont require that much space. why dont you look into a 10" sub instead? most likely will have less mounting depth as well as less air space needed
jay jay
well someone ordered the box for me and its for 2 12's. i dont know if there is a way to put 2 10's in there but i have thought about it. you think two 10's will sound better? i have around 2000 watts to push em with.
Username: Scubasteve
College Park, MD
Post Number: 827
I'd either go IDMAX or kappa perfect with a liberal application of polyfill
