Where to buy big 3
Username: Thigpen
RVA, Va Usa
Post Number: 404
any advice on where to buy your big 3 wiring?
nguyen tran
kragen
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1813
i went on ebay and got a whole spool of silver 1/0 audiopipe wire. (like 30ft) i had enough to do 1/0 power, ground, and big-3...also had about 7ft left over, so i just rolled up the slack and left it as part of my power wire.
i got the whole spool for ~$45 shipped...it was a steal. i also used 1/0 welding lugs (ring terminals) and heat-shrink from a local farm supply store.
Username: A444w444m
Post Number: 164
wut exactly is the big 3? iv never really understood it.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1484
find where mikechec09 has posted. under his name youll see a link to his cardomain website. form there there is a link all about the big3.
Username: Thigpen
RVA, Va Usa
Post Number: 405
here yo go:
http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=5;t=007801;p=
Username: Thigpen
RVA, Va Usa
Post Number: 407
could anyone link me to where i could find the big 3 upgrade to buy?
Post Number: 1816
4ga upgrade
http://www.edesignaudio.com/wire_product.php?productid=242
0ga upgrade
http://www.edesignaudio.com/wire_product.php?productid=244
or just go on ebay and by 15ft of 4ga or 0ga and some ring-terminals.
