SUbwoofer not gettin power
Username: Southside
i have my Amp hooked up and it seems right cause i got the power light working and the remote thing works. So then i used 12 gauge wire to go from the amp to the Box, i checked the connections with test light, and they all seem good. Then still my Sub will not put anything out...If someone has any ideas on whats wrong or can offer help, reply...thanks
-peace
Username: Tjmutlow
Post Number: 616
rcas could be bad or channel output is gone.
Username: Southside
Its a brand new 3000 watt mono block amp powering a new Alpine type R. I think something in the connections are not set up right..i dunno, i mean i set it all up hah
